Raptor axle Removal
Old Jun 9, 2004 | 09:08 PM
Blksnshn's Avatar
Default Raptor axle Removal
I am in the process of removing my axle and I am wondering how you get the disc brake hub off. Is it threaded or is it a spline. Or is it something different all together.
Old Jun 9, 2004 | 11:08 PM
FarmStud's Avatar
It has splines. I would highly recomend soaking it in penetrating oil and give it a few firm taps to break it loose. Mine has been really frozen on before. I tried getting it off before and it wouldn't budge, but after it soaked in WD-40 overnight it tapped right off.
Old Jun 10, 2004 | 12:10 AM
RaptorRider64's Avatar
if you are talking about the disc brake rotar, you do not need to take it off man. Unless you are replacing it. The axle should slide right out of all that stuff
Old Jun 10, 2004 | 05:47 PM
Blksnshn's Avatar
Actually it's the brake rotor hub. The part that the rotor mounts on. The hub is seized to the axle and won't come off. I've let it soak in WD 40 and a couple other lubes all night and it's still stuck on there.
Old Jun 10, 2004 | 07:13 PM
FarmStud's Avatar
Try some heat and a bigger hammer
Old Jun 10, 2004 | 07:45 PM
Blksnshn's Avatar
Well I got the axle out and now I have to get the bearings out. Looks like they wouldn''t have lasted too much longer anyways. Any good tricks for getting the bearings out. I have them soaking in lube now
STLyamwar
Jul 25, 2020 04:44 AM
toonces
Aug 5, 2015 05:55 PM
toonces
Jul 28, 2015 01:58 PM
black_thunder
Jul 22, 2015 06:01 PM
Dirtbikemike1
Jul 11, 2015 03:36 PM
