What skid plates for warrior
Old Jun 9, 2004 | 09:48 PM
jbh's Avatar
jbh
Default What skid plates for warrior
I recently got a warrior and the stock swing arm guide looks a little weak. What is the best one to buy without losing any ground clearance?
Also do you think I need and engine skid plate as well? If so any suggestions will be appreciated. I was hoping not to spend too much on this as I just purchased several things for it.
Old Jun 9, 2004 | 11:21 PM
Eceriderjbomb's Avatar
if you want to ever worry about skid plates engine should be the first thing you worry about. If i was you go to a metal shop and tell them what you need. They will make them out of whatever metal you want and thickness and will charge a lot less for better things imo.. Then the bolt you could go to a local sears or true value and pick them up.. Either way you will loose like a 1/4 inch clearence but you wouldent notice anyways.. If you feel you havce the money and would like to go factory DG and PRm make good all around plates a bumpers
Old Jun 10, 2004 | 04:20 AM
Loadtoad84's Avatar
PRM
Old Jun 10, 2004 | 04:26 AM
themadwarriorrider's Avatar
I got a moose rear skid plate on my bike. I does just fine. Ive hit several rocks on the trails with it. I also run twenty inch hole shots on the rear. I don't have any ground clearance but I got front end lifting power.
04 warrior lots of mods
Old Jun 10, 2004 | 08:01 AM
cwinter's Avatar
I just ordered a DG Baja swingarm skidplate.
Hope it fits well!!!
Old Jun 10, 2004 | 11:06 AM
Speedy2222's Avatar
Is A Power Sport Junkie!
im looking for a cheap rear skid.. i foudn a nice .190 skid somewhere for like 60-70$ gotta find it again... im looking for a full chassis skid also for cheap.. but i've seen those go for alot...
Old Jun 10, 2004 | 11:18 AM
Turtler's Avatar
I wouldnt put any swingarm skid plate on that is less than .250 thick. I had a .190 thick on the swingarm and wound up bending my rotor = $115. The .250 thick last so much longer and I have never had to replace a rotor after that. Armadillo makes a nice one.
Old Jun 10, 2004 | 11:28 AM
2000IAWarrior's Avatar
getting mine for under 40 bucks!!! its like 3/16 to 1/4 in thick.. its gonna be awsome.. but the trick is.. im gonna make it myslef.. will let ya know how it turns out..
Old Jun 10, 2004 | 12:08 PM
NLWarrior01's Avatar
You got that one yet Winter??
Old Jun 10, 2004 | 01:06 PM
cwinter's Avatar
It's in the mail!!!
[img]i/expressions/face-icon-small-wink.gif[/img]
