starts
Old Jun 10, 2004 | 05:29 PM
400sEXridr's Avatar
Default starts
what is the quickest wayto start a drag race? Should i rev the motor and pop the clutch at the light or hammer the throttle and drop the clutch at the same time when the light goes? The bike is a 400ex.
Old Jun 10, 2004 | 09:10 PM
clover's Avatar
Default starts
i would rev the motor and pop the clutch
Old Jun 10, 2004 | 11:14 PM
raptoric's Avatar
Default starts
good luck keeping front wheels on ground
rev the motor but dont pop clutch or you will be on your ****[img]i/expressions/face-icon-small-smile.gif[/img]
Old Jun 14, 2004 | 01:38 PM
Chawness's Avatar
Default starts
Start in the highest gear possible (2nd or 3rd), rev the engine to just before the limiter and dump the clutch. Change your position on the seat to allow for more or less traction. If you are on pavement, you may need to feather the clutch a bit.
Old Jun 16, 2004 | 03:22 PM
LT80's Avatar
LT80 Expert
Default starts
Rev and dump. The object is to get the tires spinning now. 2nd gear is often used. I personally use 1st, I just cannot get my R to launch in 2nd. I think it's a of weight distribution..meaning my big fat belly don't allow tire spin [img]i/expressions/face-icon-small-happy.gif[/img] I try to line up in the marbles if it's that tacky of a track.Now,mind you this is TT racing, but still a green light start, I consider it similiar to your start.
Learning is the key, yes you will raise the front if your not sitting on your gas tank [img]i/expressions/face-icon-small-smile.gif[/img]
Have a ball [img]i/expressions/face-icon-small-smile.gif[/img]
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
tiresharkdbb
Sep 3, 2017 02:06 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
