what size jets for modified warrior?
Old Jun 10, 2004 | 06:40 PM
mx8612's Avatar
Default what size jets for modified warrior?
I own a 1998 warrior and i have installed a white brothers R-4 slip-on, a FMF powerbomb headpipe, K&N air filter, wiesco piston, .450 lift cam, and a 14 tooth sprocket. I live in alabama on high elevation. I still have'nt figured out what jet is going to make my quad perform at its best though. Right ow i have a 160 main jet. The air box lid is still on. Should i change the jetting or should i get a new carbrueter?if i should change the jetting what should i change it to?thanx
Old Jun 10, 2004 | 06:43 PM
warrior68man's Avatar
Is it running rich or lean or what? I don't think you need a new carb unless you were to go big bore..
btw, did the FMF headpipe fit right onto the WB R4? or did you have to mod it?
Old Jun 10, 2004 | 07:16 PM
mx8612's Avatar
well its running lean. what size main jet should i use if i take the air box lid to?
Old Jun 10, 2004 | 07:31 PM
mx8612's Avatar
oh yea the FMF powerbomb fit right on to the white bros R-4 with no problem at all.
Old Jun 10, 2004 | 08:18 PM
kawasaki88man's Avatar
Hey this is Warrior68man I'm at kawasakimans house...if your using a 160 main jet right now and want to take the lid off...try a 170 or 175. You could always try...then go from there.
pgamboa
Dec 24, 2023 11:52 AM
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
NRA+1
1) Engine problems..
10
Sep 20, 2015 08:47 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
Brandon400
Sep 5, 2015 08:44 PM
