Scrambler HELP!!
Old Jun 10, 2004 | 08:07 PM
hoopdaville's Avatar
Default Scrambler HELP!!
I have a 400 scrambler the temp light is coming on and white smoke is coming out of exhaust. I have replaced head gasket. It doesn't start puffing smoke until the temp light comes on? Please help !!! P.s. I can't find the manual anywhere (that helps alot )[img]i/expressions/face-icon-small-disgusted.gif[/img]
Old Jun 10, 2004 | 10:13 PM
DGpolaris2346's Avatar
Maybe your running lean or you have a leak somewhere. Check the intake boot and maybe clean out your main jet.
Old Jun 10, 2004 | 10:45 PM
scramblerXrated's Avatar
did you change your oil after the head gasket swap? there might be some coolant in the oil.
X
Old Jun 11, 2004 | 12:23 AM
Quadfather's Avatar
That sounds about right. I'd check your coolant level, if it's low, I'd say you might be loosing coolant into the engine.
Old Jun 11, 2004 | 01:45 AM
pacothemonkey's Avatar
X
Silly guy [img]i/expressions/face-icon-small-smile.gif[/img] the 400... she be's a two stroke, there's no oil in the engine.
anyway, i think it sounds like a to lean/rich problem. monkey around with the carb till that smoke settles down. Good luck!
oh yeah if you need a new head anytime, i'd recommend the Prodesign Coolhead, cause they use o-rings instead of a head gasket and you don't need to replace them every time you take the head off.
Old Jun 11, 2004 | 02:09 AM
jimmypsp700's Avatar
Go here for parts list and manual online in pdf. format, copy it to your desktop and or print it off like I did.
www.polarisindustries.com/owner
exmotocrosser
Sep 13, 2019 06:12 AM
Matt123
Sep 29, 2015 01:29 AM
exmotocrosser
Sep 26, 2015 08:18 AM
Nosparkpolaris
Sep 20, 2015 04:21 PM
1000gade
Sep 9, 2015 03:35 PM
