Raptor Revs High In neutral
Old Jun 14, 2004 | 01:29 PM
matykrak's Avatar
Default Raptor Revs High In neutral
Ok so some of you may know this was My first weekend out on the new raptor, and I noticed a couple of things But first what I think is most Important. In Neuterl It will rev really fast (((((Sometimes.))))) If I give it Gas to maybe Clear the problem with hopes it will idle down It only Revs faster. I have seen others speak of this in other forums I tried a search, no luck.. Some Ideas? Idle screw? Also....Aftermarket Bars.. Who's using em' and what kind? size? etc? Yes My stock ones are already bent. Let me know...And thanks
Old Jun 14, 2004 | 01:54 PM
whiteraptor's Avatar
Your idle is set too high; refer to your owners manual to fix this.
Old Jun 14, 2004 | 02:06 PM
Yamaha660R's Avatar
You need to turn the gold screw on your carb's and lower the idle some.
Rockymountainatv.com has several differnt handle bars, and a couple are in a Raptor Style. They have some great prices on about everything for a atv.
Old Jun 14, 2004 | 03:15 PM
hondarider300's Avatar
im not sure with ur carb, but for mine the idle screw is the one that is extended out of the carb by a piece of metal and has a cord that goes into the carb, it is also brass, and yes my guess is that this is too high.
Old Jun 14, 2004 | 04:16 PM
Blaster96's Avatar
You could have a lean setting at idle. I am not sure about the rappy, but there should be a small inset screw on the carb. Adjust this (air screw) to pump more gas in at idle.
Old Jun 14, 2004 | 07:52 PM
SpArX's Avatar
Check as well to make sure the choke ain't slightly on and that all cables are not too tight, do this turning the bars in every direction too, this happens alot when switching bars out so keep that in mind as well.
Old Jun 19, 2004 | 12:41 AM
660Grizzman's Avatar
one of my friends four wheeler was idling way to low, to the point of stalling, so i just turned the idle screw about half turn and it idled right up
Old Jun 19, 2004 | 12:49 AM
radfastdude7777777's Avatar
Or your carbs are falling off of the boots, upp makes plastic boots, that eliminate this problem.The boots are the black things the carbs slide into, but the upp boots snap in. If your quad ever just stalls, and will crank, but not start, check if your carbs are on, it is a common problem.
Firefighter400
Oct 8, 2022 06:38 PM
ogio117
Polaris Side by Sides
Apr 29, 2019 03:14 PM
Schneider
Jul 24, 2015 05:05 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
