Turbo Raptor
Old Jun 14, 2004 | 02:26 PM
Raptor670yellow's Avatar
Default Turbo Raptor
Im in the process of getting togtehr the parts for a turbo raptor, What I need to know is, do the turbo raptor kits come with carbs, or does it NEED to switch to fuel injection? meaning, will a carb work with boost? I allready have the turbo setu i need, and will be making all my own pipes.
Old Jun 14, 2004 | 02:37 PM
AnimalMother85's Avatar
you can use a carburator, smokey yunik used to turbo charge a destroked small block chevy(292c.i. or something crazy like that) and he had over 1,000hp, with a carb. Anyway, you know what size turbo your gonna use? t25? I don't know if the kits come with carbs, but i'd imagine you would have to upgrade. you may want to drop your compression a bit, either that, or run less boost, like 4psi.
Old Jun 14, 2004 | 02:39 PM
oh yeah, don't let anyone talk you out of doing this either. East Coast ATV had a turbo banshee, 125rwhp out of a stock motor. Its the way to go.
Old Jun 27, 2004 | 09:25 AM
yeah, AND 4 strokes are much better with boost. See witha 2 stroke most of the charge gets blow out the ports. Im planning on copying a kit, they use garret T12
Old Jun 27, 2004 | 09:39 AM
bLuRRRR27's Avatar
Turbo Raptor
VAYA Con Turbo...
72RWHP...Stock Raptor!
Uses a Garrett T25
What a frickin beast LOL...
I saw one of these turbo kits on a raptor with the Trinity 780 Stroker kit on it also...
Absolutely insane, too bad its gotta be a gernade..
-bLuRRRR27-
(_.:**:.-«¿¤Wi©kEd §iN²7¤¿»-.:**:._)
Old Jun 27, 2004 | 11:05 AM
Majorecho's Avatar
Raptor670 have you spoken with Kelly @ KMS about their turbo raptor kit? IF the T12 is the same as the Garrett GT12 you will damage your top end and won't make any real power. IF you want variability in boost go with EFI or everytime you change boost you'll need to re-jet. Kelly spent 2 years with turbo systems on carbs with very limited success, call him so you can make an informed decision going into the project. A four stroke single can be turbo charged with a great deal of success if done correctly, my ds is putting out amazing power ( approx 100hp) with only 11lbs of boost I picked up two full gears on our comp hill , talk about a rush to ride! [img]i/expressions/face-icon-small-smile.gif[/img] Save yourself time and money and a lot of aggrevation and talk to the best atv turbo builder in the US at KMS. Good luck with your project - it's worth it!
Also the T 25 is a little too big, the correct turbo selection is key to a broad torque curve and big power at low boost levels, the lower the boost the better the engine will hold together. Kelly puts out over 82hp with about 10psi on a stock raptor and over 100 on built ( big bore) Raptors with the same boost level. Do you already have the carillo rod in? The stock rods dont handle 80hp very well[img]i/expressions/face-icon-small-disgusted.gif[/img]
Just as a point of reference a stock Raptor makes about 30hp/30 ft lbs on his dyno and a stock DS about 32hp/32ftlbs so his dyno isn't very generous at all.
Old Jun 27, 2004 | 10:42 PM
Speedy2222's Avatar
Is A Power Sport Junkie!
i wonder if the garrett turbos r ball bearing [img]i/expressions/face-icon-small-confused.gif[/img]
Old Jun 27, 2004 | 11:06 PM
Yfz450VsBanshee's Avatar
That "Malvin Company" turbo is like $4,000 isnt it?
Old Jul 2, 2004 | 12:43 AM
BALDMIKE's Avatar
Is www.mrturbo.com any good ?
Old Jul 12, 2004 | 08:11 PM
Raptoryan's Avatar
The yamaha raptor will need a garrett gt12 turbo and a carberated blow throuth system will work great i am in the process of turboing my raptor all I need is the Garrett gt12 turbo. Any ??? e-mail at raptoryan@yahoo.com
