what to use to take swingarm screw out
Old Jun 14, 2004 | 02:36 PM
vanceleeper's Avatar
Default what to use to take swingarm screw out
What do I use to take the swingarm screw off of a 98 Scrambler? I don't have a 1-3/4" wrench and space is limited between the clutch cover and the swingarm. I also don't have a clutch puller if someone was going to suggest that.
Thanks
Old Jun 14, 2004 | 04:03 PM
BUBASCRAMBLER's Avatar
I just did this.
Unfortunately I could not figure out anyway to get out of buying a socket (1 3/4). I bought a 21 pc. 3/4 drive socket set from harbor freight tool ($34.00) They have a web site if you don't have a local store.
As far as access behind the clutch cover, Pull your secondary clutch off, (no puller is needed)
Take out the 3 retaining bolts holding the cover on behind the secondary clutch.
You can then pull the cover out some and will have plenty of room to work.
Jackg17
Ask the Editor
Jul 16, 2018 04:01 AM
Beeline08
Nov 11, 2016 04:00 PM
Oct 10, 2015 10:20 AM
Jackg17
Sep 26, 2015 09:30 PM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
