marvel magic oil
Old Jun 14, 2004 | 08:01 PM
UltimateAussie's Avatar
Default marvel magic oil
my valves are sticking on my quad and i was wondering if any of you have used marvels magic oil on a quad before and if it messes up becuase of the wet clutch thing. i know that it helps the valves becuase my buddy uses it in his car. but i just want to know if it will be ok in a quad.
thanks in advance
Old Jun 14, 2004 | 09:05 PM
Turtler's Avatar
I would be hesitant to use it because it may screw up your clutch. What makes you think your valves are sticking and when was the last time they were adjusted?
Old Jun 14, 2004 | 09:09 PM
HMFIC's Avatar
I use marvel mystery oil in automobiles before but never a quad. You know you can run it in the gas to. I don't think it would hurt anything in there and it might help the valves out.
Old Jun 14, 2004 | 09:14 PM
warrior68man's Avatar
I ran a little mix of it and regular oil...did solve the problem but it ran fine and actually helped clean the motor out when I changed the oil
Old Jun 14, 2004 | 09:24 PM
I am going to pull off the head and squirt some on the valves and going to splash alittle down the fill hole. but not very much.
Thanks for the help
Old Apr 7, 2005 | 08:54 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
If you search the web, you will find that some aviation gas is leaded, and it is used to clean out lead deposits, and they put it in the gas. Whatever, don't put it in your oil.
http://www.chris-longhurst.com/carbi...&snakeoil.html
Oct 10, 2015 10:20 AM
DeFox500
Jul 26, 2015 06:32 PM
kawazuki400
Jul 17, 2003 02:04 AM
NorthernEdge
ATC 3-Wheelers
Jul 2, 2000 06:09 AM
TxDoc2
May 21, 2000 09:40 PM
