scrambler brakes?????
Old Jun 14, 2004 | 09:53 PM
paulzaho's Avatar
Default scrambler brakes?????
I have a 04 Scrambler, the rear foot brake barely does anything. I have talked to other people that have the same problem. Is there anyway to make it work as a regular rear brake? Other than the hand brake conversion. Maybe an aftermarket master cylnder? I want to be able to powerslide into the turns. Any help would be apreciated!![img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-cool.gif[/img]
Old Jun 14, 2004 | 09:58 PM
DAVEY300's Avatar
just get new brakes
Old Jun 14, 2004 | 10:01 PM
DustinMinnesota's Avatar
I bled mine and it did wonders
tbsleeper's Avatar
block off the front going into the back and get another junction box and re route the lines. why dont u just gun the gas to powerslide into the corners??
Old Jun 14, 2004 | 10:05 PM
thewayout420's Avatar
my scrammy was the same way.i bought better pads from epi and bleed them good,now the pedal is hard as a rock and locks right up.
Old Jul 5, 2004 | 03:06 AM
badassz24ondubs's Avatar
you know wha,i am currently having exact same problem. looking for solutions as well. tried bleeding it,nothing happens. like he said nothing happens,not even noticeable. when going down steep hills it would be nice to only hit the rear brake. so im listening also
Old Jul 5, 2004 | 10:05 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
If they are bled properly,,,they should work fine.
Sometimes the rear brake fluid (from the pedal) will leak past the seal in the caliper and into the brakeline for the hand brake. (like mine)
If thats the case,,,squeeze both.
I like the idea about disconnecting the hand brake from the rear,,,,,,got me thinking now.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 6, 2004 | 02:14 PM
O4scrambler's Avatar
My rear brake works fine I have never bleed it it locks right up put they are not as good for stoping like the hand brake is.
Old Jul 6, 2004 | 04:45 PM
oghma's Avatar
I have the same problem only on a sport, pretty much the same. On mine the caliper for the rear brakes is locked the piston on it does not move I think the seals inside of it are no good debating whether I should rebuild it with the new seals that I already have or just find a used caliper.
1000gade
Sep 9, 2015 03:35 PM
1ArmBandit
Sep 8, 2015 08:59 PM
oliveiracarlos
Sep 7, 2015 03:39 AM
oliveiracarlos
Sep 6, 2015 01:38 PM
