warrior tire problem
Old Jun 15, 2004 | 06:32 PM
Vipers619's Avatar
Default warrior tire problem
ya know how the front tire is suspose to be 90 degrees to the ground if it is straight. my one tire is like at a 80-85 dregrees angle to the ground but the rim ain't bent. could this be a bent lower a-arm or tie rod or tie rod end? please help
Old Jun 15, 2004 | 06:59 PM
WARRIORSCOMEOUTTOPLAY's Avatar
Need more info is it positive camber or negative?
If it's positive it could be uneven tire pressure on all four tires.
If it's negative it's most likely upper control arm.
Old Jun 15, 2004 | 10:14 PM
Vipers619's Avatar
it is hard to explain but when you go out in front of the quad and look at the front wheels the right one lines up perfect and the left also does but it is like slanted like this, /, but in the other direction and not that much of an angle.
toonces
Oct 16, 2019 12:11 PM
njrider64
Jul 4, 2017 01:40 AM
Jkfx400P
Sport Quads
Jul 5, 2015 10:33 PM
ranvette
Jul 4, 2015 06:13 PM
Nelson
Jun 20, 2015 01:59 PM
