RAPTOR CHAIN AND SPROCKET QUESTION
hello agian im going to replace my chain and rear sprocket and was going to drive up to rockymountain tommorow and get one but i have a few questions first if i get a 44 tooth rear sprocket will i be able to keep the stock skidplate? whats your opion on primary drive sprockets and chains i want a steel rear.and whats a h chain?ive heard of o and x but never h.rocky mountains got some for around 26 dolllars and it has a tensile rate of 8510 lbs is this a good chain i also noitced that some chains say designed for atv do i have to get a chain specificly for a atv? what size of chain should i get for a 12 44 combo??will the stock 520-92 work?
THANK YOU FOR ANY HELP YOU CAN THROW MY WAY
JUST DONT THROW TO HARD
yea you want to gear down from the sounds of it and its easier to just get a new front b/c they are easier to change and 1 tooth in the front is = to two teeth in the back. if you are getting a new chain just b/c of the new rear sprocket its not worth it. if you are replacing the chain for another reason then i can see why you would want to do that. so now the choice is yours
I believe he posted something about his chain falling off earlier. Im not too sure if its same guy, but he is from utah [img]i/expressions/face-icon-small-wink.gif[/img] Good call on getting steel back sprocket and a new chain though. Many people suggest O ring or Xring chains they are a little more expensive, but are said to last longer. For me, any chain gets wasted by the sand here, so i stick with regular chains.
i already have a 12 tooth front sprocket on the front and its 3 teeth to 1 not 2 to 1 and yes im the same guy who lost his chain off the rear sprocket i have went to 22 inch tires 2 iches taller than stock and i want the bottom end back can i just put some washers on to make some more space on my skid plate??
how much taller is a 44 tooth from the stock 40?
joeyupton
Jul 14, 2015 11:51 AM
