only one side sparks!
Old Jun 17, 2004 | 10:44 AM
AnimalMother85's Avatar
Default only one side sparks!
ok, my banshee gets spark, on the right side. The left side, well, it doesn't allways, and when it does, its in hi rpm's, and then it back fires. whats going on here? any ideas?
Old Jun 17, 2004 | 11:33 AM
anyone?
Old Jun 19, 2004 | 11:56 AM
elexan1's Avatar
Just had the problem over the winter and it was very fustrating!! But I did find the problem and fixed it (myself). Yamaha uses universal spark plug boots. These are the kind that you cut 3/8" of the end of the wire and then jam the boot on effectively splicing the wire onto the boot. Although Yamaha offers theier version over the counter at the dealer...don't buy it it won't fix (the boot hits the head).....Buy the one for it OE ONLY from the dealer..it's only 23.00 dollars and it will work as long as the last one. P.S. you only get one shot at a ew boot, they mke the wire from the coil too short to ty more...If yours was aready done, ou'll have to replace the coil under the hool (80.00) and do the gnd wire at the same time (they get rusty)
The reason why you guys are getting mixed results after changing plugs is because your shaking the connection to the plug
This happened on a one cylinder though!!
Chillibean
1) Engine problems..
Sep 5, 2020 04:02 AM
jeepwheelin02
Jul 18, 2020 06:42 PM
ScopeZ_
Jul 28, 2015 01:44 AM
Ty64
Technical and How-To Articles
Jul 25, 2015 02:02 PM
Unzzy66
Jul 11, 2015 10:01 PM
