New chain ?
Old Jun 17, 2004 | 05:20 PM
scootergptx's Avatar
Supersock
Hired Gun!
Default New chain ?
Got a new O-ring chain and I'll be putting it on next week. Do you soak O-ring chains in gear oil like we used to do with a non O-ring chain? I've got some Slick 50 gear oil (80/90w) left from my old truck I never used, would that be ok to use, or just regular gear oil? Thanks!
Old Jun 18, 2004 | 12:38 AM
Quadfather's Avatar
Default New chain ?
Don't soak it. It's ready to go out of the box. The pins are sealed, and they're already lubed up with lithium grease. Ride it for a while, then hit it with some chain lube that is for O ring chains. Keep it lubed, it will last a long time, unless you are installing it on old, worn out sprockets. If your old chain was worn out, so are your sprockets. You should change all three items at the same time.
Old Jun 18, 2004 | 01:09 AM
BUBASCRAMBLER's Avatar
Default New chain ?
I would think you would want to avoid OIL
Rubber (O RINGS) and oil do not get along
Only use an O-ring safe chain lubricant.
Old Jun 18, 2004 | 02:04 AM
mudmaster250's Avatar
Default New chain ?
what i did to soak it was i got a bucket and some chain lube from napa for an oring chain and put the chain flat on the bottom and sprayed it and sprayed it until it was sitting in enough lube to coat it and thats all i did then i lubed it after the first ride.
Old Jun 18, 2004 | 03:41 PM
Supersock
Hired Gun!
Default New chain ?
Thanks! I'm changing the sprockets too, keep looking out the window waiting for UPS. Thinking about leaving the plastic chain guard off. This is the second time broke off and wrapped around the front sprocket.
Old Jun 18, 2004 | 06:17 PM
Default New chain ?
you got lucky if it wrapped around the sprocket, thats what mine did and it cracked the case well beyond repair.
mrtidy
Feb 3, 2016 05:00 PM
kbazzy
Sep 26, 2015 11:26 AM
merryman
Sep 19, 2015 03:15 AM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
