CHAIN SIZE AND SELECTION WHATS A H CHAIN?
Old Jun 19, 2004 | 04:31 AM
BURKEDADDY's Avatar
Default CHAIN SIZE AND SELECTION WHATS A H CHAIN?
hello again what size chain should i get for a raptor 660 with 12 tooth front sprocket and 44 tooth rear sprocket i was thinking 520-94? stock is 520 92 right?also what is an h chain ive heard of o and x but i was thinking about buying a primary drive h chain. over 8000lb tensile and cheap so i was leaning that way.
THANK YOU
Old Jun 19, 2004 | 05:05 AM
JakalWarrior's Avatar
Thats a non oring chain right? those kind are higher maintanance and hate water.
Old Jun 19, 2004 | 05:12 AM
BURKEDADDY's Avatar
higher maintanance how?what more do you have to do to them?
Old Jun 19, 2004 | 05:22 AM
Without o-rings sealing up the inside, the inside will rust, then the rust wears off, and its stretched. Eventually its not usebale and more likely to break. To prevent that you have to always keep it lubed before and after every ride. O ring chains use an Oring on each side to keep their lube sealed in.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
carid
Sep 14, 2015 03:40 PM
bvolks
Sep 13, 2015 12:57 PM
bmark0610
Sep 7, 2015 09:42 PM
