Squeaking Noise??
Old Jun 23, 2004 | 09:18 PM
thebutelr's Avatar
Default Squeaking Noise??
Ever since i've had my 350x i have always noticed a squeaking noise when i compress the back suspension. Could this be the swingarm bolt being too tight, or could it be something squeaking in the shock linkage? Its gettin really annoying and i can't seem to find what it is. Thx.
Old Jun 23, 2004 | 09:50 PM
HMFIC's Avatar
Have you tried greasing all the fittings on the rear linkage.
Old Jun 23, 2004 | 10:28 PM
thebutelr's Avatar
Are you sure the 350x has grease fittings?? Because i just looked the whole back end over and did not find a single one. Are they supposed to have them?
Old Jun 23, 2004 | 10:44 PM
HMFIC's Avatar
I am not sure about the X. I know my 85 R and my banshee have them.
Old Jun 24, 2004 | 01:38 AM
sharpie's Avatar
i dont belive the x has any greese fittings.. jsut pull things apart and slap some greese on before you put it all back together. hopefully things arnt all stuck.
Old Jul 12, 2004 | 07:03 PM
350xrulz's Avatar
No they dont come with grease fitting in the swingarm. But if you take the swingarm off, you can put a grease fitting in the middle of the swingarm (where the bolt goes). The honda dealer did it for me when I had my bearings replaced. Good luck!!
Old Jul 12, 2004 | 11:02 PM
MY86ATC350X's Avatar
it might be your top bolt that connects with your frame on your rear supension my 350x was making the same noise i removed the top bolt and i filled the bolt with grease around it and i swaped it back in and the noise stopped but dont tighten it too hard. do that i recommend you. it worked for me and if it still makes it do the same to the bottom ones.
peace...
mrtidy
Feb 3, 2016 05:00 PM
Ahtatu
Sep 28, 2015 12:14 PM
kbazzy
Sep 26, 2015 11:26 AM
Canamaniac!
Sep 4, 2015 06:44 PM
