200s engine in a 200x??? will it work
Old Jun 25, 2004 | 01:47 AM
Pudgedawg007's Avatar
Default 200s engine in a 200x??? will it work
ok i have had a 200s engine in my garge for a couple years now i came across a 200x with a frozen engine and i wanted to know if anyone has done it the mounting bolt look the same but i am curious about the wiring/cdi will the cdi/wiring from the 200x work with the 200s engine. i know i could just rebuild it but i am trying to get my wife into riding and i think the 200s's automatic tranny would work alot better for her
Old Jun 25, 2004 | 12:47 PM
Blazerone22's Avatar
Yep it will bolt right in, you need to use the 200x exhuast, intake manifold, I used the 200s electrics, but I'm fairly sure the 200x stuff will work. You will need to rig up a rear brake pedal since the 200x mounts on the motor, or use a left hand master for the rear brake.
Old Jun 28, 2004 | 01:08 PM
Madwolverine's Avatar
The stator coil wiring is different. It can be spliced to work or you can install an x stator in the s engine.
Old Jun 29, 2004 | 04:45 PM
threewheelinfeelin's Avatar
should work fine ive seen many people make auto x's
Hankey Pankey
26
Oct 18, 2020 03:50 PM
EZRyde
EZ Ryde Exhaust
Jul 30, 2015 12:46 PM
VRRRRT
Jun 27, 2015 09:38 AM
200x hill climber
Ask the Editor
Jun 10, 2015 11:11 PM
wildbill59
May 28, 2015 12:05 PM
