99 Sportsman 500 hard steering.
Old Jun 25, 2004 | 01:57 PM
Madcap's Avatar
Default 99 Sportsman 500 hard steering.
It seams that the sterring is getting a lot harder. It feels like it is in 4 wheel drive. Will the sterring bushings cause this to happen?
Old Jun 25, 2004 | 02:05 PM
Whitewater's Avatar
Harder...how? On the flat, sidehills??? Is something that has just happened or has it come on slowly?
Old Jun 25, 2004 | 02:18 PM
Madcap's Avatar
It just seams to be getting harder. I just started to notice it.
Old Jun 25, 2004 | 02:24 PM
Whitewater's Avatar
There's a grease zerk on the steering post - try that first.
If that doesn't work, jack up the front-end and have someone turn the handle bars. Look / listen for bushings, seal boot and ball-joint problems.
Old Jun 25, 2004 | 02:27 PM
BUBASCRAMBLER's Avatar
Pick the front end up and see if it seems stiff.
Have you greased the UPPER and LOWER support?
I know pre2002 scramblers have grease zerks at the support bushings.
I guess you could see if the ball joints or upper struts are binding.
Is it in and out of 4 wheel drive? or is the 4wd binding?
The only other (Not likely) this is to check the tightness of the lower steering shaft nut, if some how it has been over tightened it will cause hard steering.
GregM
Mar 6, 2018 06:53 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Gtsordo
Jul 22, 2015 01:27 PM
ghost civic
Jul 19, 2015 10:13 AM
Johnclay
Utility ATVs
Jul 19, 2015 10:00 AM
