electrical problems
Old Jun 25, 2004 | 07:40 PM
mudbucket's Avatar
Default electrical problems
I have a 1996 bearcat 454 4x4.I had a problem locating a new shaft for it,so it set up for about a year.Now that I hav it back together.I can't get no fire from the spark plug.Can anyone give me a clue on what might be wrong.Is it the plug,the coil, or the cdi box.I would appreiate any good help.Thanks to all..............
Old Jun 27, 2004 | 10:19 PM
shorty16's Avatar
arctic cats suck
Old Jun 27, 2004 | 10:32 PM
FAStCAT7806's Avatar
Look And Search for the right parts it also serves as a diagram of assembly.
No need to talk bad about any quad "SHORTY" unless you have the ***** to back it up!
Old Jun 27, 2004 | 10:44 PM
Bear4570's Avatar
mudbucket; Well first off "shorty 16" is and A$$. I don't have a diagram of the '96 wiring, but I'm pretty sure the is a test proceedure with a meter you can do, atleast there are for the later models. You need a meter and a test procedure out of a manual. Did you test for fire with the old plug itself, if so get a new plug and try it, I've seen plugs go bad from sitting. Also check to make sure the run-stop switch is in the run position(been there done that). If that doesn't help then disconnect the run stop switch. Otherwise make sure nothing is killing a good system. Oh yeah, you might check fuses. Pull and then reinstall them, sitting that long can cause all kinda strange problems. You should get a manual, try the libarary it's free and if it's like mine you can find and order what you want on line.
skinnyr6
Aug 25, 2023 02:18 AM
TheHood
Jul 26, 2015 09:51 AM
Chuck188
Jul 17, 2015 02:45 PM
Unzzy66
Jul 11, 2015 10:01 PM
ranvette
Jul 4, 2015 06:13 PM
