300EX trouble
Old Aug 8, 2000 | 05:52 PM
94DGblaster's Avatar
I still can't get a spark out of my 300EX!
I replaced Coil, Reverse inhibitor box, And the Pick up coil.
No spark nothing..not even the hint of a spark.
Startor works, lights work, everything. But it won't spark at all. Nothing..
The only thing left is my CDI box, and i don't see how it could be that.
The stator is working. When i put a light on the stator wires it lights the light up. So i don't think it's that.
Any suggestions? Anyone want to buy this POS?
Thanks all
Old Aug 8, 2000 | 07:27 PM
BlueBlaster's Avatar
How do you know it is not the CDI box? There is no way really to test a CDI box, because the way they are designed. If you know anyone else who has a 300EX put their CDI box in your to find out. IF you tested everything else and they checked out, it more than likely it is the CDI box.
Old Aug 8, 2000 | 08:48 PM
I've never heard of a CDI going out. Never ever..
Old Aug 8, 2000 | 08:56 PM
NVR2L8's Avatar
If I'm not mistaken, the black and yellow wire which is connected to the positive side of the coil, is what signals the coil to fire, so it could very well be your CDI. I agree, find another known good CDI and see if that's your problem.
Check this also... Peel back the rubber boot on the stock clutch perch housing, and look for two green wires. Make sure they're connected to the switches inside the perch housing. My 400EX had a similar problem with no spark and/or would only start in neutral, and it was one of these two wires not being connected...can't remember which one though.
Old Aug 8, 2000 | 09:15 PM
250xRacer's Avatar
the reverse switch also keeps the motor from firing. check and make sure it's not in reverse.
CDI boxes do go bad i have had one go bad.it doesn't happen very much but they do go bad.
Old Aug 8, 2000 | 10:43 PM
i am going to look for a used CDI box, I don't know anyone that owns a 300EX any more.
So i guess i'll call up K&K ATV and see if they got one..
Old Aug 9, 2000 | 08:53 AM
Exer_95's Avatar
If no luck with K&K.. Give East Coast ATV.. Mine went bad, and I got one from them !!! $50 !!
Tell them Jason Gray sent you !!
Jason
95wolv
Sep 27, 2024 12:00 PM
mrtidy
Feb 3, 2016 05:00 PM
Clint Russell
Sep 25, 2015 03:20 PM
MikeyBoyesq
Sep 22, 2015 10:02 AM
Bonzhonda300ex
TheATVSuperStore
Sep 17, 2015 01:21 PM
