rear axle nut
Old Jun 26, 2004 | 07:42 PM
insaine's Avatar
Default rear axle nut
hey does anybody know what way to turn the rear axle nut for ir to come off. im not sure if its like a normal nut right is to tight left is to loose or is it the oppisite way around. thanks
Old Jun 26, 2004 | 09:34 PM
sixsixT's Avatar
normal
Old Jun 27, 2004 | 12:04 PM
insaine's Avatar
cool, thanks alot.
Old Jun 27, 2004 | 02:19 PM
insaine's Avatar
do you have to loosen the inside nut (locking nut ) first or do you just loosen the outside nut and then the inside nut.
Old Jun 27, 2004 | 09:54 PM
RaptorRacer1's Avatar
If this is the first time you've had it off it will probably be VERY difficult. Mine was on my Raptor. I finally had to
1- put it in gear
2- strap down the rear brake
3- remove any set screws from the nut
4- heat the nut with a blowtorch
5- use a big wrench or crescent wrench with a piece of 2 foot long pipe slipped over the end of it to give you more leverage
take off the outside one first, then the inside one should come off easily. When putting it back together be sure to torque them as directed in the service manual.
Good Luck
RR1
mywifesquad
8
Sep 21, 2015 08:20 AM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:57 PM
bmark0610
ATC 3-Wheelers
Sep 7, 2015 07:48 PM
black_thunder
Sep 7, 2015 01:24 AM
snowolson
Aug 31, 2015 03:51 PM
