DS650 no fire problems. need help
Old Jun 27, 2004 | 10:20 PM
chadscrambler's Avatar
Default DS650 no fire problems. need help
ok 2 weeks ago I was riding and shut it off and it would not start. everytime I hit the starter the little solinoid in the backside of the battery would either buzz or click depending on where the starter switch was.. was it turns out that a loose ground was causing that and now it turns over but we are getting NO spark to the plugs, everything else is working and we are getting power to the coil but nothing to the plugs.. is there a fuse or something that would be cutting power from the coils becuase I find it hard to believe that both coils would go bad at once.. anyone got any ideas what this could be??
Old Jun 27, 2004 | 11:43 PM
DaSandBomb's Avatar
That's tough one, loose ground wires are no fun. I assume the kill switch is in the On position(it will turn over in the off postion just no spark). Check connectors under the dash are to make sure they are tight, check coil wires. Try a new plug. If you have a good freind with a DS, try a differant CDI (it controls the spark). Is the battery fully charged? try a battery charger while turning over. Check to make sure ther are no other ground wires that my be loose.
Like I said. it's a tough one but just keep trying things.
Old Jul 1, 2004 | 10:16 PM
Snyderman's Avatar
I had the same exacy problem. check to see if you have power coming out of your cdi box, I did not so I bought a new one and that was my problem. my old box was stock my new one is ron woods.
ultangler
Nov 30, 2024 01:35 AM
mrtidy
Feb 3, 2016 05:00 PM
IMLN
Sep 28, 2015 03:32 PM
Elkaholic
Sep 6, 2015 02:44 PM
Jason An Stacy Jones
Utility ATVs
Sep 6, 2015 02:25 AM
