Swingarm Bearings???
Old Jun 27, 2004 | 11:54 PM
warrior68man's Avatar
Default Swingarm Bearings???
Are they hard to change on a Warrior? I got mine running(Stupid orange wire came off the igniton box) and the swingarm bearsing are bad...are these hard to change? Is it pretty much a lift the quad up, take the bolt out, and change the bearings? Or is it more complicated?....Please help em out here guys...or gals....thanks.
Later
Old Jun 28, 2004 | 12:33 AM
TTT...I need to know if this is hard or not guys....call me impatient or not...lol...this forum rocks and I know someone out that has to know.
Old Jun 28, 2004 | 12:53 AM
2faST4yUO's Avatar
since no one is answering your post i will try to help you out the best i can. first you take the pivot bolt out. i would take the whole rear assembly of such as the axel, chain. to were you just have ur swingarm. then take out your bearings. if i were you i would use bearing removers/instalers. they are the only tool to use. i wouldent use anything differant. if u have a service manual it helps alot. that is a key thing to have. if u do not have on i would get one. also the bearing should come with instuction too. follow those. this is not much info but i hope it helps. good luck and ride safe
wendal
Aug 3, 2024 10:03 PM
exmotocrosser
Sep 13, 2019 06:12 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
jbrewster94
Sep 23, 2015 04:16 PM
