new tires
Old Jun 29, 2004 | 12:41 PM
yamahas4life's Avatar
Default new tires
i bought a used blaster and i just bought new tires for it. i noticed that one of the bolts that keep the tires on is stripped almost completly off how can i get it off
Old Jun 29, 2004 | 01:38 PM
moldycheese's Avatar
Default new tires
if you feel brave use a grinder or a file to flatin the sides on it so you can put a wrench over it
Old Jun 29, 2004 | 01:40 PM
Default new tires
do you know of any other ways because i cant fit a grinder or file in there to flatten out the sides plus that would take forever
Old Jun 29, 2004 | 01:53 PM
Bing's Avatar
Super Quad Patrol
Smokes meat all the time!
Default new tires
vise grips
try heating it up a little with a torch
Old Jun 29, 2004 | 02:23 PM
Default new tires
after you heat it up what do you do i tryed the vise grips but i cant turn them do you know of a way that makes it easier to turn the vise grips
Old Jun 29, 2004 | 06:07 PM
grizzlyfan's Avatar
Default new tires
If vise grips won't work you may try to use a small pipe wrench with some sort of cheater bar that should work. You may have to apply a little heat to it also.
Old Jun 30, 2004 | 03:27 PM
MongoDS's Avatar
Default new tires
Find an old socket that is just a little to small and beat it on there with a hammer, it'll break loose but your socket is probably F.U.B.A.R that is why you need to find an old one.
Sep 30, 2015 01:37 AM
Ahtatu
Sep 28, 2015 12:14 PM
PinkFloydEffect
Sep 25, 2015 06:31 PM
cboler9
Sep 24, 2015 08:35 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
