blaster problem ....need help quick
Old Jun 29, 2004 | 02:25 PM
sickblaster00's Avatar
Default blaster problem ....need help quick
ok well i was rideing down a dirt rode in 6th gear i let off the gas to make a turn and i wasnt slowing down so yeah i hit the kill switch and locked up my brakes i fialy came to a stop i started it back up agian and the enige was reving so high i thoguth i was going to blow my motor. so i figured my trotal was sticking does anyone have any ideas how i could get this to stop or maybe its a differant probelm i need help quick thats for the help guys
Old Jun 29, 2004 | 02:28 PM
Shav0's Avatar
First off, check the tension on the throttle cable. Sometimes before on my blaster the cable would tighten when you turn the bars one way. Check to see if it is pulling on the cable first..
other then that, you might have a problem with the tors.
Old Jun 29, 2004 | 04:20 PM
RoscoePW's Avatar
sometimes the throtle cable cagtes loose and pulls out a little tricking the negine into thinkins your giving it gas... happened to me on a scrambler 500, at 45mph.. good luck'
almost died lol
Old Jun 29, 2004 | 08:39 PM
Criminalpoet's Avatar
Check to make sure that you didnt blow a base gasket because your problem sounds like a lean condition. You wouldnt be the first if you did. If thats not the problem lube your throttle cable real good.
Old Jun 30, 2004 | 07:49 AM
thanks for the help so far if it is a lean condition how can i fix it......... and how do i check if i blew a base gasket
Old Jul 2, 2004 | 01:05 AM
AtvSpeed's Avatar
i have a questoin for all you guys and gurls out there with chain driven atvs. im lookin to get an atv this summer and i want a chain driven one, but my dad doesnt because back in the day he had a 3 wheeler and he said he had sorts of problems with his chain. so i am asking everyone, do yall have any problems with yalls chains like links breaking and chains falling off? i really want to know so i can convince my dad to getting a chain driven atv.
Thanks
Old Jul 2, 2004 | 03:35 AM
02blasterguy's Avatar
well i havent had any trouble yet or known anyone with that much trouble sometimes u may need to tighten them but thats most until you decide to get a new chain(just to make sure that nothing happens)even at that its been 2 years and i still have the same chain.
Frisky2050
Apr 9, 2020 11:19 AM
bzdok1234
30
Feb 23, 2016 01:55 PM
joeyupton
Jul 14, 2015 11:51 AM
Bob Maurice
1) Engine problems..
Jul 14, 2015 09:05 AM
black_thunder
Jul 9, 2015 05:58 PM
