what size pilot jet? Banshee, T-5's, no airbox, clamp-on K&N's, 300 main.
Yeah like dragman side you should be at at around a 30. I think stock is a 25. Your Idle is all controled by you pilot so it will have nothing to do with the main jet or the needle. You should look into your carbs to see where your floats are at they should only be a little bit of an opening. If ther is to much or just not enough opening you will have a rough Idle and you should adjust your Tors. Your air screw should be started at 2 turns out and go in to lean it out and out to richen it up. I think or is that backwards.
Good luck
Good luck
