what size pilot jet? Banshee, T-5's, no airbox, clamp-on K&N's, 300 main.
Old Jun 29, 2004 | 05:45 PM
wreckspert's Avatar
Default what size pilot jet? Banshee, T-5's, no airbox, clamp-on K&N's, 300 main.
just wondering, cause it won't idle for crap no matter what i adjust so i'm guessing it's getting no fuel.
Old Jun 30, 2004 | 12:12 PM
pinheadedjoker's Avatar
my buddy has the same setup hes running a 280 main at 5000 feet.. maybe ur running rich? he is on stock pilots also
Old Jun 30, 2004 | 12:14 PM
2004LEBANSHEE's Avatar
Where are your air screws at.
Old Jun 30, 2004 | 12:15 PM
try turning the tors **** to increase idle speed. there the **** on top the carbs.
Old Jun 30, 2004 | 12:54 PM
02DragMan's Avatar
You need to run a 30 pilot.A 27.5 will work but the 30 idles better.
Old Jun 30, 2004 | 01:36 PM
Banshee2003's Avatar
Yeah like dragman side you should be at at around a 30. I think stock is a 25. Your Idle is all controled by you pilot so it will have nothing to do with the main jet or the needle. You should look into your carbs to see where your floats are at they should only be a little bit of an opening. If ther is to much or just not enough opening you will have a rough Idle and you should adjust your Tors. Your air screw should be started at 2 turns out and go in to lean it out and out to richen it up. I think or is that backwards.
Good luck
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
Canamaniac!
Sep 15, 2015 06:19 PM
mbriggs
Sep 13, 2015 10:47 AM
