hesitation need to FIX on a tm45, help!!
Old Jun 30, 2004 | 10:33 AM
shmee's Avatar
Default hesitation need to FIX on a tm45, help!!
this has probably been talked about before but cannot find it. so i have a stage 2 rwr and from idle to 1/4 or so it stumbles. or when you blip the throttle at low rpms. any ideas please!!
Old Jun 30, 2004 | 10:36 AM
SANDMAN430's Avatar
if you took the airtube from the airbox to the carb off put it back on and try a 155-160 main jet it should be pretty good.
Old Jun 30, 2004 | 10:42 AM
shmee's Avatar
i run rw recomended jetting 145- 40pilot-middle clip at about 1700 feet. but where does the hose go on the carb??
Old Jun 30, 2004 | 10:46 AM
SANDMAN430's Avatar
it's the tube that went to the back of the carb to the air box where the filter was. and if you are running the airtube the 145 is to lean
Old Jun 30, 2004 | 10:49 AM
shmee's Avatar
i must be stupid but i didnt know there was a place for that hose on the tm45.
Old Jun 30, 2004 | 10:54 AM
SANDMAN430's Avatar
it's the tube air intake on the back side if the carb, it goes from 4 inch's to about 2. its about 12 inch's long, goes back to the air box. is all that stuff still on you quad?
Old Jun 30, 2004 | 11:22 AM
shmee's Avatar
there is no tube on the back side just the front
Old Jun 30, 2004 | 12:27 PM
sam's Avatar
sam
Are you running the accelrator pump? dont sound like it.
Im running the pump W/ 32.5 pilot, 145 main right now it snaps really hard off the bottom needle clip in the second slot from top. allthoe Im only in a stg 1.
so you have a clamp on filter?
you might want to PM Hightower, he is running a stg 2 as well and has his diald in.
Old Jun 30, 2004 | 12:39 PM
shmee's Avatar
no acc pump, i did some more reading and there must not be a fix. i did pm hightower no answer yet. i think these carbs are so tuchy every little mod you will have to rejet. expecially from stage 1 to 2.
Old Jun 30, 2004 | 02:06 PM
SANDMAN430's Avatar
there not that touchy at all i never change jets that much at all. maybe were talking the wrong side of the carb.
