weight reduction
Old Jun 30, 2004 | 01:01 PM
01blazer's Avatar
Default weight reduction
i have a 2001 trailblazer and I need to know what i can do to make it lighter than what it ways stock.
Old Jun 30, 2004 | 01:35 PM
BUBASCRAMBLER's Avatar
It all depends on what you want to live with out.
The simple thing are replace you factory steel equipment with aluminium. Things line Wheels, Running Boards and front bumper. You can go aftermarket or some earlier Scrambler 400/500 models were equipped with aluminum wheels, Running boards and front bumper from the factory.
Next you will be removing conveniences (Battery, Starter, Oil Injection, Oil Tank, Cut plastic) The removal of these items come with sacrifice so, how bad do you want to eliminate weight
Old Jun 30, 2004 | 02:22 PM
mudmaster250's Avatar
get a new pipe. teh difference in my stock pipe to my rcr pipe is amazing, bars will make a little difference. then u can remove mounting tabs that u dont need. every little thing counts.
Old Jun 30, 2004 | 02:38 PM
markbanger's Avatar
You can remove you sprocket gaurd weighs about 5 pounds and gives you some more power.
shimanok2
Jan 29, 2016 07:37 PM
Robinhood
Dec 26, 2015 10:28 AM
Steeldon
Sep 9, 2015 09:38 AM
antiguogrumete
Sep 5, 2015 03:41 AM
