Socket sizes????
Old Jul 2, 2004 | 11:42 PM
1BigDSRider's Avatar
Default Socket sizes????
I'm going to pull the rear hub in the morning. But none of my sockets fit the nut on the end of the rear axle's hub. Anyone know the size??
Also what is the socket size for the front sprocket???? Changing up the gearing.
Old Jul 3, 2004 | 12:26 AM
TheChosenOne's Avatar
I am pretty sure the rear hub is 1-1/16 or 1-1/8" Like I said I am pretty sure as I just had mine off. I used a wrench, and I got enough of it to get it off.
Old Jul 3, 2004 | 01:57 AM
busmechanic's Avatar
36mm and 30mm
Old Jul 3, 2004 | 02:00 AM
Thanks for the replys.
Old Jul 3, 2004 | 08:16 AM
bombrider's Avatar
front sprocket is 30mm, dont know the hub ones.
Old Jul 3, 2004 | 08:35 AM
BillDS650's Avatar
rear is 36 mm
Old Jul 3, 2004 | 03:55 PM
Thanks everyone for the help. Changed the sprockets and launching out of second is very easy now. Only problem with the 15/42 gearing with the stock tires is wheel spin. Those dominators dont hook for $hit. Going to have to invest in some 22inch holeshots or Razors.
The correct sizes for the sockets are 30mm for front sprocket and 36mm for the rear hub.
One more thing what and the He!! did they put those bolts on with. My impact couldnt take them off. Had to use a 3/4 drive socket and a two foot cheater bar, and put all my weight on it. Thats alot of force with my 6'3 320lbs frame.
Old Jul 3, 2004 | 08:47 PM
BillDS650's Avatar
Counter shaft nut torque is 100Lbs rear hub nut torque is 176Lbs
Old Jul 3, 2004 | 09:48 PM
yea, I had the same issue with the nuts the first time around. clean and lude splines and threads with anti seize lube. it will be much easier next time.
Old Jul 4, 2004 | 12:58 AM
Yes they were a pain. But there back on now and I used antiseize for the hub. Thanks again.
Levi Enstad
Sep 26, 2015 08:00 AM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
rgjackson
Sep 23, 2015 01:53 PM
toonces
Sep 5, 2015 01:14 PM
snowolson
Aug 31, 2015 03:51 PM
