tm 45 question
Old Jul 3, 2004 | 11:27 PM
thebigshow's Avatar
Default tm 45 question
i just switched back my carb back to gas. well i took it out for a test ride and it ran great, no problems.then i got to cruising back to my house when it started cutting out real bad and i could smell gas a little. i let it sit for a couple of hours and came back and it started right up and ran like a champ, about 15 minutes later it did it again.....im wandering if has to do with that thing a ma gig that regulates the float. rwr told me i didnt have to change that back, has anyone else ever encountered this problem?
Old Jul 4, 2004 | 01:06 AM
DCryder's Avatar
I always leave the oversized float needle and seat in mine even when I run gas. Maybe float is sticking???
Old Jul 4, 2004 | 02:16 AM
thebigshow's Avatar
would that cause it to start cutting out?
Old Jul 4, 2004 | 11:48 AM
SANDMAN430's Avatar
was gas coming out of the over flow?
Old Jul 4, 2004 | 12:46 PM
thebigshow's Avatar
i didnt notice any,but then again i really dtdnt look.it did stick and come out the overflow when i turned my gas on. i had to tap the bowl with a wrench to get it to stop.
Old Jul 4, 2004 | 12:53 PM
SANDMAN430's Avatar
seems if the float sticks i see fuel out the over flow, which would go with what you thought.
Old Jul 6, 2004 | 08:54 PM
thebigshow's Avatar
well i changed out the float today. i rode it around for about 20 min pretty hard. nothing.... so i started putting back to my shop to put her up and she loaded up and died again...i let it set about 5 min and as long as i rode it at 1/4 throttle or better it did fine but as long as i putted it died.....soooooo....would that make u think my pilot jet is to big, i turned the air mixture screw out but it didnt help a whole lot...i didnt have this problem with this jet earlier on this year .....what do u guys think?
Old Jul 7, 2004 | 01:52 PM
thebigshow's Avatar
bump...
Old Jul 7, 2004 | 02:57 PM
sam's Avatar
sam
thebigshow,
I dont know if this will help you or not or if you already got it but its the Mikunt manuel for the tm45 manual link scrol down its in PDF format. this has helped me with dialing in my pilot and a couple other things. by chance did you look or replace you needle and seat to see if its clean? it almost sounds like some thing is sticking and if its not the floats or needle and seat then maybe the slide? the next time it happens if you can look down the carb to see if the slide is seated all the way down. if you were running alky B4 maybe some thing is wore out .Just a thought
Sam
Old Jul 7, 2004 | 03:22 PM
biggerisbetter's Avatar
what are your jet sizes? do you have the accelerator pump active? if your air/fuel screw is more than 2.5 turns out, you need to go down on your PILOT jet. how about your needle? what position is it on?
bigger.
