Oh Shoot!!!!!!
Old Jul 4, 2004 | 05:57 PM
thebutelr's Avatar
Default Oh ****!!!!!!
Omg, today i was taking my exhaust off to get it painted and i broke the ends off of the bolts to hold the head pipe on!!!!! That piece of junk I think i'm pretty much screwed cuz i don't think that they are able to come out, this thing was really nice too [img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img][img]i/expressions/face-icon-small-sad.gif[/img]. Does anyone know what i can do to possibly fix this?? I need some help asap.
Old Jul 4, 2004 | 06:16 PM
ATVman00169's Avatar
will mabe if you were to get a small enuff drill bit. you could drill in to the bolt some and then mabe use the bit to un screw it. or work some old bolt that would fit the size of the hole you made and screw it in there good and tight. (so its stuck is there) then you would be abile to un screw the bolt. .......i hope mabe this works. will its an idea.
Old Jul 4, 2004 | 07:06 PM
thebutelr's Avatar
Does anyone know whether these bolts come out or are they molded into the head??? Cuz if they are i might be able to get them replaced, but has this ever happened to any of you guys?? Help! Thanks in advance.
Old Jul 4, 2004 | 07:38 PM
PlatinumDogg's Avatar
i believe that the bolts should screw out, they do on my 200m...jus should drill the centre of the bolt out, and im not positive, but i think they make screw extractors small enough that u might be able to fix one in there..if not...good luck with that
Old Jul 4, 2004 | 10:09 PM
kooroc's Avatar
try a left hand drill bit. worked great the other day for me. start with 1/8" then 3/16" and so on (i'm not sure of the size of bolt). if you are not getting anywhere, try a bolt extractor (i like the square type).
Old Jul 5, 2004 | 01:06 AM
thebutelr's Avatar
If i take it to a honda shop will they be able to take out the broken off studs and replace them with new ones?? Also if they can (or will) how much money do you think it will run me? Thanks for all your help guys.
Old Jul 5, 2004 | 01:35 AM
kooroc's Avatar
i'm sure they would love to take them out $$$$$
i would have to try.
did the heads break loose or were they rusted to pieces?
did they break clean (flat)
Old Jul 5, 2004 | 03:12 AM
thebutelr's Avatar
The studs were pretty much frozen solid to the nuts and when i tried to take them off they just broke off clean at the end leaving most of the studs still sticking out. I think i'm just gonna let my local honda shop do it (i don't have the time to do it myself), i know i'll be kicking myself later cuz of the price but if thats what it takes to get them fixed the right way then i guess i shouldn't complain. Hopefully i'll have this thing up and runnin in a week or two [img]i/expressions/face-icon-small-smile.gif[/img]. She's gonna be purdy with the new plastic & seat i bought.
Old Jul 7, 2004 | 02:56 AM
thebutelr's Avatar
Do you all think that a shop should definantly be able to take out the studs and put new ones in if i had the engine out of the frame?
Old Jul 7, 2004 | 11:13 AM
HA2's Avatar
HA2
yes.
