whats have u replaced or fixed on your scrambler 500 or 400
Old Jul 6, 2004 | 05:43 PM
IDLE's Avatar
Default whats have u replaced or fixed on your scrambler 500 or 400
what have u guys fixed or replaced
Old Jul 6, 2004 | 06:32 PM
scrambler123's Avatar
just the rear brake pads.
Old Jul 6, 2004 | 06:49 PM
BeltDrive's Avatar
Nothing yet. I hope like scrambler123 it will be brake pads.
Old Jul 6, 2004 | 06:54 PM
tbsleeper's Avatar
ur just gonna have to endure this long post[img]i/expressions/face-icon-small-disgusted.gif[/img]
i have replace my brake pads, rear bearings because theres mud and rocks behind my house, and my front sprocket and chain twice. sorry for the long post but it would have been 4 times longer if i had a yamaha [img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 6, 2004 | 09:37 PM
DGScrambler400's Avatar
my chain and front CV boots
Old Jul 6, 2004 | 09:50 PM
ftwflh's Avatar
Scrambler nothing major.Sportsman you name it I have broken it.
Old Jul 6, 2004 | 10:01 PM
thewayout420's Avatar
ive replaced swingarm bushings,rear axle bearings,rear axle,stearing post,stearing post bushings,chain and sprockets,a-arm bushings,ball joints,tierod ends,im sure there is something else also..but i still love the machine and wouldnt trade it for any other..
Old Jul 6, 2004 | 11:35 PM
Wolverine350R's Avatar
Fixed: all brakes replaced, bypassed rev limiter (killed machine when throttle was pressed),
Needs: Chain and Sprockets, air filter (cleaning), tie rod ends, steering post bushing, all the wheels (did them in in 2 days), there appears to be metal in the front hubs and front housing, will not start if both headlights are plugged in (I dunno?), I need to flush out the brakes ( ust found that the other day).
I've had it 3 months I think...
Old Jul 6, 2004 | 11:49 PM
EAB's Avatar
EAB
On my wifes I had to replace the belt and the elbow at the bottom of the coolant overflow bottle. On mine the upper steering bushing should be replaced, and I had to do a top end but that was my own dumb fault (tried a smaller main on a cold night in the dunes).Also on mine I had to replace the air filter hold down in the air box, I think that was my fault also from over tightening the wing nuts.
Old Jul 7, 2004 | 12:47 AM
BigBadScrambler's Avatar
Ive replaced:
Belt (trying a few different types)
brake pads
chain and sprockets
ball joint
tires and rims (upgraded)
exhaust (upgraded)
air filter (for K&N)
various clutch parts (part of clutch kit)
1 hillard clutch cage
both hub seals
headlights (upgraded)
radiator hoses (maintence)
radiator petcock
cv boots
and a cv joint
