Rancher ES problems
Old Jul 6, 2004 | 07:12 PM
Stoney667's Avatar
Default Rancher ES problems
I got a Rancher 350 ES 2x4 and the gear number will start flashing and i can't shift. We've manually shifted it back into N and then it will work again for a while then do it again.....well lately we can't even ride it......and about a week after mine started doing it my sisters Recon starts doing the same thing! its an ES as well.....I have warranty and they are going in the shop this week..Just wondering if anyoen else had this problem.....i'm about ready to trade in this es b/c its the 2nd time mine has done it! The first time the ES controller unit lost a bolt and fell off......
Old Jul 6, 2004 | 07:36 PM
maddog56's Avatar
Sounds like it could be out of calibration but I doubt it unless you damaged it when it fell off. Usually when that shifting problem happens all you have to do is rock the machine and it will shift, its just in between shift points.
Old Jul 6, 2004 | 07:55 PM
Imperitas's Avatar
Yeah, rocking the quad side to side and up/down seems to do the trick. Have you tried doing this?
Old Jul 6, 2004 | 08:05 PM
Stoney667's Avatar
yep it doesn't matter it still flash's......but my sisters doing it to is weird, its in gear, it just won't allow u to shift since its flashing......
Old Jul 6, 2004 | 09:17 PM
250xRKrider's Avatar
does the speedo work, or not?... if not i know the problem
Old Jul 6, 2004 | 10:12 PM
Stoney667's Avatar
speedo is on at 00, if you get it to N you can rev it and it'll show like 2mph like it always does.....
Old Jul 7, 2004 | 12:56 AM
JokerGuy's Avatar
You may have something going on like in this previous post - read all the posts
Previous Post
Old Jul 7, 2004 | 04:32 PM
exactly, thats wat i was getting to, b/c i was the one who resolved that problem, so i was thinking it was the same. does the speedo keep reading 00 when u ride the atv, like 2nd gear or so? if so refer to my post on the previous post
Old Jul 7, 2004 | 06:00 PM
Stoney667's Avatar
checked all the wires, can't find anything cut or broken....
Old Jul 7, 2004 | 08:06 PM
u checked the wire that i mentioned in the previous post that i replied to? thats always the cause of the ESP failure, b/c the wire is exposed to anything that could come from the ground and cut it.
