wheel spacer question, advice needed.
i am having a little bit of tire rub on the front tires when the wheel is turned all the way in one direction. i was wondering if anyone is running just spacers on the front wheels? would this be a dissadvantage in the mud since the rear tires would be inside the fronts?? also what kind is everybody running, highlifters the best? they don't rub with the suspension at the lowest setting but when you crank it up all the way, which is what i like it set at, the top of the shock rubs, just to clarify. also does anyone have any that they want to get rid of?
P.S-you guys popping axles running spacers? do you feel that this adds to the problem? i have an 03 with 1 04 axle and 1 03 axle in the rear, i don't want to pop an axle.
