z400 snorkel
what exactly does the snorkel do for a quad, and why do u have to remove it to gain preformence after adding an hmf pipe[img]i/expressions/face-icon-small-blush.gif[/img]
dont want to sound stupid, but i want to know this stuff
and anyone who ordered the hmf pipe, what jetting did u run. i ordered a 170 main and that was it.
I picked up a K&N filter for mine and the guy at Alba recommended that I remove the lid and snorkel and use a 165 main and 3 turns on the air screw. Its for better air flow and less restrictive like FsT4WrD said.
Originally posted by: FsT4WrD
Have to clean the air filter every couple of rides
and if i remove the snorkel and dont like it not there, is it a pain in the a$$ to replace it.
The snorkel just pulls off, and is easily put back in. It's held in with a rubber grommet. All the snorkel is really for is so that if you get yourself in water that's kinda high....it still gives a path for air through your airbox. Other than that....it's really useless. It does restrict some airflow....because of the foam around the tip, so you will gain a little more air.
If you still have the stock filter, I'd highly recommend getting a high flow filter as a replacement. It's almost pointless to buy a pipe (slip-on or full) and not get the filter. Unless, of course, you just want your Z400 to sound better. The stock filter is very restrictive in comparison to either a K&N or Twin Air or UNI.
You don't have to remove the whole snorkle, just the end cap that is held in place by two tabs. I left the tube on cuz the ears with the hole was perfect to hold that vent hose that was previously held by the end cap.
