straight piped 400ex
Old Jul 7, 2004 | 10:47 PM
NDrider400's Avatar
Default straight piped 400ex
Does anyone know for sure, that it will damage or wreck the motor in a 400ex if you straight pipe it?
Old Jul 7, 2004 | 11:16 PM
450r's Avatar
you need a certain amount of back pressure for an engine to work properly. besides , just cause its loud doesnt mean its fast.
Old Jul 8, 2004 | 12:11 AM
Eceriderjbomb's Avatar
very correct plus why would you want to run straight pipe?
Old Jul 8, 2004 | 12:14 AM
450r's Avatar
i raced a strait piped yfz at sand mntn. and it was nothing more than loud.[img]i/expressions/face-icon-small-wink.gif[/img]
Old Jul 8, 2004 | 10:12 AM
Raptorlegs's Avatar
T Rex Rider
What irritates me is!
Those 6-packs work pretty good.
I'm going to play the devil's advocate.
Go ask Dale Earnhardt if he'd run a muffler on his race car.
Same principal. I think tuning the head pipe and jetting would be the key though. Maybe the intake since all three work together. Might lose some low end.
Old Jul 8, 2004 | 02:35 PM
HMF440racer's Avatar
My HMF is Basicly a straight pipe and it really opened it up from stock
Old Jul 9, 2004 | 01:43 AM
450r's Avatar
how can a 600 hp v8 be compared to a 25 hp single cylinder motor .just the amount of flow required to make that motor run is probably enough to suck start a harley. it needs the most free flowing exaust out there, but dont think because there's no "muffler" that there is no back pressure in the pipes, thier bent and cut to whatever length for that . if the had monster blowers they could run 2 foot pipes. after that much hp exhaust no longer matters so long as it gets the heat away from the motor and flows as much as it takes in.
Old Jul 9, 2004 | 01:50 PM
Raptorlegs's Avatar
T Rex Rider
A headpipe will provide all the backpressure you need if it is the right length and diameter. All a baffle will do is distort the airflow and hinder performance.
Old Jul 10, 2004 | 11:43 AM
NDrider400's Avatar
Does anyone know what size pipe I should use? Would stock size be alrigh?
Old Jul 10, 2004 | 01:20 PM
450r's Avatar
ill bet that motor does'nt last a year. even drag quads run expansion chambers and "mufflers". how many has anyone seen not running any sort of backpressure causing devise.
