straight piped 400ex
Originally posted by: 450r
you need a certain amount of back pressure for an engine to work properly. besides , just cause its loud doesnt mean its fast.
I'm going to play the devil's advocate.
Go ask Dale Earnhardt if he'd run a muffler on his race car.
Same principal. I think tuning the head pipe and jetting would be the key though. Maybe the intake since all three work together. Might lose some low end.
how can a 600 hp v8 be compared to a 25 hp single cylinder motor .just the amount of flow required to make that motor run is probably enough to suck start a harley. it needs the most free flowing exaust out there, but dont think because there's no "muffler" that there is no back pressure in the pipes, thier bent and cut to whatever length for that . if the had monster blowers they could run 2 foot pipes. after that much hp exhaust no longer matters so long as it gets the heat away from the motor and flows as much as it takes in.
A headpipe will provide all the backpressure you need if it is the right length and diameter. All a baffle will do is distort the airflow and hinder performance.
