my buddy needs help
Old Jul 11, 2004 | 12:04 PM
scramblerXrated's Avatar
Default my buddy needs help
my buddy has an '03 TB400. he just bought the HSP speed kit. it is installed and he pissed....
its REAL fast once the engine revvs a little and the clutch kicks in.
but what hes pissed about is, there no throttle reponse. he used to do wheelies till the sun went down and now he has no bottom end power. cant even pop the front up alittle. we double checked everything and it should all be installed properly.
if this is normal, and this kit is really made for top end power, then the HSP website is misleading. it advertises a bottom to midrange power increase, giving you the HOLESHOT!!!!
well, theres no holeshot here.
any one else had this issue? is there something that can be done? or is that the nature of the kit?
our ride got rained out today, so were gonna be tinkering in the garage.
please lemme know,,,
X
Old Jul 11, 2004 | 12:28 PM
tbsleeper's Avatar
the secondary doesnt sound like its in the 2-2 position. there is freeplay where the engine will rev but the clutches will not engage thats just normal u have to time the wheelies just right.
Old Jul 11, 2004 | 01:34 PM
markbanger's Avatar
Sounds normal he will get use to it and will be able to wheelie easier and better once he gets the hang of it. Thats what mine was like to after I put all my mods on.
Old Jul 11, 2004 | 01:55 PM
BeltDrive's Avatar
ScramblerX your friend should be able to wheelie very easy. From a stop he should be able to nail the throttle and stand it right up on the grag bar. Have him give HSP a call to make sure everything is setup right. Did he preload the secondary spring like the directions say.
Old Jul 11, 2004 | 03:35 PM
paulzaho's Avatar
I have the hsp kit on my '04. At first I did not preload the secondary spring and it wiped out my "ramp buttons" After replaceing them and installing the spring in the 2-2 position, also PRELOADING the spring. My 4x4 will stand straight up on take off. I would just double and triple check your install.
Old Jul 11, 2004 | 03:39 PM
tbsleeper's Avatar
ya i was thinking its not in the 2-2 position either or maybe it is but wasnt preloaded
Old Jul 11, 2004 | 04:07 PM
EAB's Avatar
EAB
Did you install both shims at the exhaust flange? I ran mine for about a year with no shims, then tried the shims, and had to go way up in the jetting. From a 250 to a 310. Also when I added the shims the pilot circuit was too rich and it would bog on the low end, then take off like a rocket.
Old Jul 11, 2004 | 04:19 PM
tbsleeper's Avatar
i always wondered wat the shims would do, i always run mine without them?!?!
Old Jul 11, 2004 | 08:00 PM
hey thanks guys, i will pass on this stuff and see if we cant get thos handled.
appreciate the advice!!
X
Hack714
Oct 6, 2015 06:51 AM
Hack714
Sep 26, 2015 08:11 AM
Irishman301
Sep 23, 2015 01:47 PM
Hack714
Sep 20, 2015 05:54 PM
Canamaniac!
Sep 15, 2015 06:19 PM
