200x top end head torque pressure?
Old Jul 12, 2004 | 10:15 PM
MY86ATC350X's Avatar
Default 200x top end head torque pressure?
I want to know what ft. lbs. torque needs to be set on the head of a 83-85 200x motor.[img]i/expressions/face-icon-small-confused.gif[/img]
Old Jul 13, 2004 | 02:04 PM
haywoodjalikme's Avatar
Well first of all the four 8mm head bolts are 20-22 ft-lbs and the four 6mm bolts and phillips screw head bolt are 6-9 ft-lbs. These should tightened in 2-3 steps and in sequence.
Front of Engine
***7******9****
****4*****2****
*5*************
****1*****3****
***8******6****
This is directly from my Honda Service Manual, hope it helps.
Jeff
Old Jul 13, 2004 | 02:39 PM
ThrashAndCrash's Avatar
I have 13-14 ft.-Lbs on the 8mm bolts.......you sure that you did not mean 20Nm???????????????? But I have the same on all the rest.
Old Jul 13, 2004 | 04:16 PM
well what about the 4 12mm bolts that are in the center on the valve cover? what ft. lbs do those have to be?
Old Jul 13, 2004 | 04:48 PM
12mm head is the 8mm bolts....8mm thread diam.
Old Jul 13, 2004 | 04:50 PM
oops thanks
Old Jul 14, 2004 | 07:12 PM
Wow I found something interesting!
My Honda Manual says 20-22 ft-lbs for the 8mm diameter head bolts,
and my Clymer Manual says 13-14 ft-lbs for the same bolts.
Both manual state the same 6-9 ft-lbs for the 6mm bolts.
HHMMMMM which is correct? I used the Honda Manual specs for when I rebuilt my X with no problems but I remember it felt kinda funny on the last sequence.
Maybe just to be safe I would contact your local dealer, since when I rebuilt my X I replaced the head bolts and got the last of them from Western Hills Honda who carries alot of older parts. And if they don't have them your almost SOL on finding any.
Jeff
Old Jul 15, 2004 | 02:54 AM
good point.......set mine to the lower #'s and I blew out my first head gasket after about 2 months.......used the same specs on the 2nd one and I am fine so far.........MY86ATC350X..if you call a dealer let us know what they say so we can change it in our books if need be.
Old Jul 15, 2004 | 04:12 AM
yea i guess ill go to Cycle Stop Honda Service to make sure.. dont want to blow a head gasket too. thanks for the updates guys
Specta
Family ATVing Photos
Dec 7, 2018 08:22 PM
1ArmBandit
55
Oct 14, 2015 09:03 PM
Steeldon
Sep 9, 2015 09:38 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
Steeldon
Utility ATVs
Sep 5, 2015 09:38 PM
