Jetting (and other) Questions
Old Jul 13, 2004 | 06:25 PM
jusrlax's Avatar
Default Jetting (and other) Questions
I am awaiting delivery of my Mister HP end cap for my 03 DS 650. I got bored last night and decided to take apart the top of the carb (using the unbelievably helpful prior posts on this subject as a guide). I found that the "C Clip" was set on the fourth position from the top (flat end) of the needle. So, my understanding is that moving the clip down one more notch (towards the sharp end of the needle) will make it richer. Assuming I will be using the stock needle, and that I ride at sea level (Pismo/Dumont/Glamis), which is most likely to be the proper needle position once I install the end cap, once I change to the correct main jet?
Also, I have read the posts that describe cutting 4-6 coils off of the "carb spring" for better throttle response. Is the spring that is cut the big, thick spring that is held down by the gold colored metal piece that makes up the top of the carb, or the tiny spring that is part of the needle assembly? Obviously, I don't want to cut the wrong one. Is there any downside to doing this?
I have read the posts about using zip ties to re-route the snorkle tubes outside of the frame. Can anyone post a picture of the correct way that this should look? Last night, I noticed that there is a black hose that comes up from the motor and goes into a hole in the snorkle tube on the left side (looking from the back). If you put the tubes outside of the frame, what do you do with this hose and what do you do about the pre-existing hole in the left vent tube?
Thanks in advance for your help. Reading this forum has given me confidence to do things that I never before would have done (like take the carb apart and try re-jetting myself).
Old Jul 13, 2004 | 06:35 PM
dirtydays's Avatar
Who's the manufacture of your Carb and how do you jet for say, 8000 ft elevation
Old Jul 13, 2004 | 07:22 PM
JMAC650's Avatar
The spring you want to cut is the bigger one that is held down by the gold cap. Start with 4 coils.
Old Jul 13, 2004 | 08:45 PM
TheOz's Avatar
JMAC650: That's a sweet machine you're selling. You've put some time and duckie ($$$) into customizing your machine. Many of us will be interested to know how much you sold her for.
Old Jul 13, 2004 | 09:00 PM
JMAC650's Avatar
Still for sale.
Old Jul 14, 2004 | 12:58 PM
222's Avatar
222
All of those questions can be answered by emailing or calling MrHp, but personally I wouldn't want to put that kind info on the forum any more because there are those that copy products then use all of his testing information such as carb settings to sell their's without any testing or expense!!!!
Considering the Thousands of $$ poured into testing cams, pistons, porting, etc.... , the endcap isn't that big of a deal, but what will they copy next?
Anyway, he'll gladly talk to you about those questions since you bought it from him and, I don't know, but he might talk to someone about it even if they didn't.
Good luck
222
Old Jul 15, 2004 | 07:35 PM
atvaddict01's Avatar
What exactly does cutting the spring do?
Old Jul 15, 2004 | 07:43 PM
DSengineer's Avatar
Has been here a long time!
It allows the slide to open faster.
Old Jul 15, 2004 | 08:36 PM
Im carb stupid. The slide does what?
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
