Dim Headlight question on a 01 400ex
Old Jul 16, 2004 | 02:46 AM
curlytop's Avatar
Default Dim Headlight question on a 01 400ex
hey guys, long time no talk. but anyways i have a problem, if you havent noticed it yet i bought me an 01 400ex a while back and just the other day my right headlight wasn't as bright as it is suposed to be ( like it is barely on) and i can push inward on the lens and it will turn on like it is suposed to, but as soon as i hit the smallest bump it does the samething again. i was wondering if this has happened to any of yall and what did you do to fix it. Please help me on this cause i do alot of night riding and that one light REALLY makes a difference. Even if it hasn't happened to you, let me know what you think could be wrong. thanks
Old Jul 16, 2004 | 01:47 PM
Sparkey's Avatar
Since pushing in on the headlight temporarily fixes the problem I would start there. Check the plug for corrosion broken or damaged wires etc. Check the terminals on the light for being loose or damaged. Check for a bad ground. Perhaps the light it self is damaged. trace the circuit back throught the switces, all the way to the battery if necessary. dirty battery cables, weak battery etc. I will bet that it is near the headlight itself.
Old Jul 16, 2004 | 04:22 PM
SickRider's Avatar
what he said
Old Jul 16, 2004 | 05:46 PM
NotuRaptor2's Avatar
Check where the bulbs connect into the sockets. If the back of the bulb is worn down, you can melt more solder to it thus giving it a "renewed" hump. This fixed a similar problem I was having without having to purchase new bulbs.
Old Jul 16, 2004 | 08:25 PM
curlytop's Avatar
another question, how do i disconnect my headlights when i take off my front plastic, i couldn't figure it out last time i had my plastic off. but i didn' t look really hard tho.
Old Jul 18, 2004 | 09:04 AM
use a small screwdriver to help pull the connectors apart if necessary.
XxS0ccerstarxX
Oct 18, 2021 10:03 PM
MooseHenden
Sep 6, 2015 04:24 PM
Logan Collins
Sep 5, 2015 08:03 PM
jeff mc
Dunes and Dune Machines
Sep 3, 2015 07:47 PM
XxS0ccerstarxX
Aug 7, 2015 06:18 PM
