4 wheel drive ? on 95 400 scrambler
Old Jul 20, 2004 | 10:08 AM
FMFScrambler400's Avatar
Default 4 wheel drive ? on 95 400 scrambler
My 4x4 won't kick in and i don't know why the front axels are spinning but the front wheels aren't spinning and the awd light won't turn on. can anyone help I think it's electrical probwhat do you think
Old Jul 21, 2004 | 12:41 AM
quadwrench's Avatar
One frequent problem I see is the gear selector switch does not register the quad being in Forward - if the Neutral light is on, or the Reverse light is on, then the AWD light will not come on and will not allow AWD - try running AWD with the override button pushed in.
Old Jul 21, 2004 | 07:53 AM
ftwflh's Avatar
Make sure the AWD light bulb is not burned out.
Old Jul 22, 2004 | 12:32 AM
scrambler4racing's Avatar
If your problem is electrical with the gearshifter, don't buy anything . It is easy to re-wire so that it will work all the time, forward and reverse. I had the same problem and fixed mine in about 10 minutes. Look at your wiring diagram and bypass the rev limiter and gear selector switch.
scram5050
Aug 30, 2024 01:39 PM
jrubicon
Where to Ride
Oct 8, 2015 01:05 PM
KimSJoh
14
Jul 18, 2015 07:20 PM
rcappie4
Jul 18, 2015 07:51 AM
maxjung
Jul 13, 2015 05:11 PM
