BANSHEE DRAG SLICKS???
Old Jul 20, 2004 | 10:23 PM
hondaguy13's Avatar
Default BANSHEE DRAG SLICKS???
I HAVE A BANSHEE I RUN ON 1/8 MILE ASPHALT AND I AM RUNNING HOOSIERS RIGHT NOW AND THEY DON'T HOOK FOR NOTHING EVEN IF I HEAT THEM UP I NEED TO KNOW MAKES A SLICK FOR A TEN INCH RIM AND IF THEY ARE BETTER THAN MY HOOSIERS?
Old Jul 20, 2004 | 11:19 PM
Turbo33's Avatar
Which Hoosiers are you running? If you're not hooking up you a need better set up, It's not the tires.
Old Jul 20, 2004 | 11:35 PM
hondaguy13's Avatar
18x11x10 tri-tracs
Old Jul 21, 2004 | 12:58 AM
Outlawlawndragster's Avatar
If you want light weight and soft compond mickey thompsons m2's are the best . you can even have then recaped with softer compunds .
if you want softer but a little heavier go with american racer dt23 there a 10" tire for flat track but extremly soft and durable
Old Jul 21, 2004 | 12:17 PM
AlkyBurninX's Avatar
Tri-tracs are made for loose dirt/sand tracks. Hoosier makes a drag tire that is used for Jr dragsters. They have a 18X10X8 and a 18X8X8. The MT's that were mentioned also are for Jr dragsters. The AR dirt track tires hook well also.
That must really be a bada$$ bike to run a 6.1 while spinning.
MikeyBoyesq
Sep 22, 2015 10:02 AM
Nosniborpapa
Sep 12, 2015 05:54 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
HondaR24
Jul 16, 2015 10:45 AM
Jul 7, 2015 11:00 PM
