highest compression piston
Old Jul 20, 2004 | 11:16 PM
JUS2KOOL2K's Avatar
Default highest compression piston
I wanted to know whats the highest comp. piston I could get for a Raptor so I could still use 92 octane gas?
Old Jul 20, 2004 | 11:46 PM
hondaguy13's Avatar
i have heard that 11:1 is the highest you can go on pump gas
Old Jul 20, 2004 | 11:53 PM
Turtler's Avatar
I heard the same 11:1 from the guys who did my tranny rebuild and piston swap since the cases were split.
Old Aug 18, 2004 | 06:38 PM
ravencr's Avatar
I had contacted JE about this same thing, and they make a 10.75:1 standard bore piston that they recommend if still running pump gas. It includes the picton, rings, pins, and clips and tha part number is 190253 for the raptor.
My question is who else makes pistons for the Raptors? Who is best?
Chris
Old Aug 18, 2004 | 06:42 PM
caliraptor's Avatar
I got a Wiseco 11:1 and Ive been running 87 octane without any problems.....I might try 91 and see if it helps any.
Old Aug 18, 2004 | 06:57 PM
ravencr's Avatar
Are quads like cars in that if you have a high flowing exhaust, the compression decreases a tad inside the chamber? It's funny how some people say that they are running 87 octane when others are saying with the same piston they have to erun 93 octane. Other than altitude differences, what could be causing this wide difference?
Chris
Old Aug 18, 2004 | 07:23 PM
caliraptor's Avatar
I would think they are the same as cars, 4 strokes work the same way. Ive got an e-series pipe without a spark arrestor so its pretty much a straight pipe, dont know if it hurts compression but it sure does sound mean [img]i/expressions/face-icon-small-cool.gif[/img]
Old Aug 18, 2004 | 07:26 PM
ravencr's Avatar
Yeah, see I'd bet that if you ran the stock pipe/exhaust, you'd have to run higher octane gas.
Chris
Old Aug 18, 2004 | 09:37 PM
Doctorturbo's Avatar
GOT BOOST!
Many things. Some of them are:
#1. Load
#2. Ambient air temp
#3. Cam timing
#4. Cam profile
#5. Combustion chamber and piston shape
#6. Exhaust back pressure
and even air cleaner efficiency just to name a few
Old Aug 18, 2004 | 10:34 PM
etwake's Avatar
Running anything higher than a 10:1 compression you should be using at least 91 octane gas. It combusts a lot better than 87. Plus you get the added benifit of the cleaners from the gas in your engine.
