any Polaris mechanics out there? elect. problems
Old Jul 24, 2004 | 10:10 AM
timurray's Avatar
Default any Polaris mechanics out there? elect. problems
AWD - won't engage, no light either
speedometer - not working
speedometer - no light
going forward - hit override button - reverse light comes on
reverse - you can go full tilt without hitting override button
I've got to believe these problems are all linked but I have no idea what it would be.
Dealer told me AWD is linked to speedo but I'd rather not leave it for him to "troubleshoot" for hours.
Old Jul 24, 2004 | 12:51 PM
MoosEye's Avatar
I hate electrical problems!
Old Jul 24, 2004 | 01:56 PM
Polaridoo's Avatar
Did these problems just show up from normal use? Or did something else 'strange' happen - like maybe drowning it in a puddle?
The answer will probably help where to go from here.
If you have a manual, I would start looking into how to test different components.
Old Jul 24, 2004 | 10:51 PM
timurray's Avatar
These problems came up after installing a new battery. I had accidentally left off a ground cable and I pull started it for a couple of days to get my work done. Once I got some time to troubleshoot, I saw the gound cable stuck behind the battery. Connected it, it started great. I don't remember if the probably was immediately after this or not.
Old Jul 24, 2004 | 11:37 PM
deanz400's Avatar
id get a scematic and start from there sounds like a possible short or crossed wires ..
Old Jul 25, 2004 | 01:28 AM
700quadman's Avatar
Don't know what's causing these problems but Polaris is easy to troubleshoot. Get a wiring diagram & check that all the wires are pluged into the correct spot on the connector board under the center plastic. Everything is color-coded.
Old Jul 27, 2004 | 08:18 PM
Brushcrusher's Avatar
Seem to remember reading something about a totaly dead battery causing problems like those.
Sorry I don't recall the details.
Try calling a few shops or ask on some more forums.
Old Jul 27, 2004 | 08:54 PM
Polaridoo's Avatar
I think you cooked something. Since I am not familiar with your specific ATV, the first thing I would look for is blown fuse.
Old Jul 27, 2004 | 11:59 PM
timurray's Avatar
I'm betting on a blown speedometer. From the schematic, everything that i see wrong, connects to the speedometer. They're only 2 weeks backordered from Polaris. Must be a common problem.
Old Jul 28, 2004 | 02:16 AM
700quadman's Avatar
OK unplug the speedo & see what happens. Just follow the color-code.
