Need Help With Atc 200m
Old Jul 26, 2004 | 10:42 PM
MyHatetredBleeds's Avatar
Default Need Help With Atc 200m
I Need To Know What The Valve Clearance Needs To Be Set At.
Would It Hurt The Motor Running It With Out A Silencer On It, But With Just A Straight Pipe From The Header Out To The Back?
Old Jul 27, 2004 | 12:28 AM
PlatinumDogg's Avatar
According to my clymer..should be set at .002..exhuast and intake...make sure to adjust with the piston at TDC on compression stroke...while the engine is cold
Yes, it will hurt the motor to run with out the muffler. IF you remove the muffler, u loose all back pressure. You will find bottem end is like a 2 stroke....jk lol, but it will be very weak...and ull burn your exhuast valve up soon enough.....when u remove the muffler, the whole motor will lean out, and everything burns so much hotter that things melt, and u have some major problems on your hand. IMO...just leave it as is, or buy an aftermarket exhaust...ie, supertrapp
Sean
Old Jul 27, 2004 | 01:05 AM
Ok, thanks alot. i ran the exhaust like that cause the sliencer on it was shot. and it kind of broke off, and i didn't have the money to buy one.
I was told that it depends on how long your exhaust is. that it wouldn't hurt it to run with out one.
My friend has a resonator off a car on his 3-wheeler for a sliencer, would that work. or would it hurt it also?
Old Jul 27, 2004 | 01:18 AM
Hmm..im not to sure....my buddy had a ricer exhuast on his 400 something..is wasnt an ex..something else, and it was cool at the time being, a exhuast froma civic, it was huge the muffler lol...4-5 inch diamter, 15in long, loooked wicked on the quad, but its performance dropped drmatically, due to not being enough back pressure....
I guess if it is long enough, but if its only your header, definately gonna melt somefin.... IF you do go with striaght exhuast, get a long pipe, and set ur main jet incredabily high lol[img]i/expressions/face-icon-small-happy.gif[/img]...
When my buddy had the civic exhuast on, when ever it was pinned, flames would be shooting out the back..kinda sweet if you ask me lol[img]i/expressions/face-icon-small-happy.gif[/img]
Old Jul 27, 2004 | 11:34 AM
the valves should be set at .002. thats with a stock piston, right?
but would it be the same with a high compression, high dome?
Hey i have a glasspack off my brothers truck, i should try that for an exhaust.
Old Jul 27, 2004 | 01:16 PM
Im running high compression piston, with the high dome, and mine are set at .002....there are slots in the piston so that the valves will clear the piston..i dunno to what depth, but its a good amount
Old Jul 27, 2004 | 01:47 PM
Alright, I called dave dixion, and he said .002 intake, .003 exhaust.
brockway honda said 3-4.
So i'll go with what you said.
hey do you know where i can get a wiring diagram for my 200m. theres some wires that were cut on it and i need to see if i need them or not.
Old Jul 27, 2004 | 05:56 PM
Go to this page
Its exact for you trike
Sean
Old Jul 27, 2004 | 08:42 PM
thanks alot.
hey i put my 3 wheeler back together, and everything. started on 3ed pull. but it was running at full throttle for some reason. shut it off, mess around with it, now it won't start.
o yeah i figured out what was wrong with my starter. the solenoid is bad.
Old Jul 28, 2004 | 12:46 AM
Im thinkin maybe your adjusted something with your carb...is it sealed up tight...between the filter and the engine it self...
You said you messed around with it...what exactly did you do..im wondering now, as to why it wont start?[img]i/expressions/face-icon-small-confused.gif[/img]..
I know on mine, i did a carb rebuild, i was messing around with it, and i moved the jet needle clip up a notch, and it would rev quite high and not come down... it should be on the 3rd notch.
sean
