Direct Shifter for Raptor
Old Jul 27, 2004 | 07:42 PM
maddog56's Avatar
Default Direct Shifter for Raptor
I was thinking of putting a direct shifter on my raptor. The main question I have is how you would adjust the height without any linkage. Just wondering if anyone else had done this and had some input for me. Thanks.
Old Jul 27, 2004 | 08:10 PM
Hayseed's Avatar
It's a splined shaft. With the IMS, you're not out much. I like mine.
Old Jul 27, 2004 | 09:15 PM
RaptorOwner's Avatar
Same here and it works better than my Pro Design direct shifter that cost twice as much.
Old Jul 28, 2004 | 02:55 AM
Yamaha660R's Avatar
So you guys prefer the IMS direct more then the Pro Design Power shifter?
Old Jul 28, 2004 | 03:09 AM
dirthead's Avatar
Yeah, which one would be better for fast/aggresive trail riding and playing on a mx track.....does one give you a better shift then the other, and which one has a better throw to it....TIA
Old Jul 28, 2004 | 10:25 AM
Dfitz's Avatar
I have both, used the IMS first then put on the Pro design. Both work the same, just the PD is better quality. JMO
Old Jul 28, 2004 | 12:31 PM
TheRaptorMan's Avatar
Is the Banshee direct shifter the same as the Raptor? Is it the same splines, but different bends or what? Just curious!
Old Jul 28, 2004 | 01:05 PM
The banshee has the same splines but not the same bend. I had to modify one(bend it to fit my raptor once cuz my shifter broke) and it worked!!
Old Jul 28, 2004 | 01:08 PM
Thanks Raptorowner! I was curious if they were the same or not.
Old Jul 29, 2004 | 05:49 AM
bLuRRRR27's Avatar
STAY AWAY FROM ALBA.....there shifter uses the frickin linkage and rubs on the side of ur engine, its horrible.....stick to IMS, they are the best! JMO....
-bLuRRRR27-
