Jetting w/ HPD pipe
Old Jul 29, 2004 | 12:20 PM
SethL11's Avatar
Default Jetting w/ HPD pipe
I recently bought an RCR stage 1 kit with an HPD pipe. I have the brown primary spring and run a 160 jet. I moved the clip from the 3rd to 4th position from the top and now i have no low end power. I think that by lowering the clip it is recieving too much gas and that is the reason why its so sluggish, will raising the clip back to the stock position help me out? Also, I am unsure which spring I have, it is brown with an orange stripe, is this a mid or top end spring? Thanks
Old Sep 6, 2004 | 01:02 PM
Springlite's Avatar
It is sluggish on the bottom because it is flooding out. Move the clip up one at a time. Ride around and see which position it rides best. Be careful on the top setting so it doesn't lean out and burn up. I had the same problem and moving up the clip made a huge difference. When it starts to run a little better, adjust your fuel/air mixture screw. It's best not to go out more than about 2 turns on the 250.
Old Sep 6, 2004 | 01:08 PM
thewayout420's Avatar
do some plug checks,just guessing where to set the clip and where to set the mixture screw isnt the way of doing it..
ReconBayou
Oct 31, 2022 05:37 PM
mrtidy
Feb 3, 2016 05:00 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
Brandon400
Sep 5, 2015 08:44 PM
