another one of those jetting questions
Old Jul 29, 2004 | 01:30 PM
UltimateAussie's Avatar
Default another one of those jetting questions
i have a LT 185 and i now know that i have to rejet becuase my plug keeps on fouling and then my bike wil not start. but i have never done any jetting in my life so i am clueless. do i need to go up a siz or down a size or should i go up two sizes or down 2 sizes, you get the idea. but where do i find the current jetting. and where should i get the jets.
thanks in advance
Old Jul 29, 2004 | 02:53 PM
hondabuster's Avatar
You can start by reading about carbs and now they work.
Heres some places to start.
jetting
carb 101
Old Jul 29, 2004 | 03:28 PM
i understand how a carb works i and i know how the jetting works but o dont know what size i should replace it with i now know that right now it has a 115 main jet on it and becuase it is running rich should i go down a few sizes
Old Jul 30, 2004 | 01:59 PM
It depends on which circuit, is doing the fouling. If the idle circuit is doing the fouling, then changeing a mian jet wont have any effect.
You have four circuits in the carb, they can independantly be rich or lean, and not have much effect on the other circuits.
Is it only rich when wide open.....then its the main jet. If its fouling plugs while idleing or very low throttle openings, then a mixture screw adjust, might be all you need.
Have you done a compression check? It could be oil fouling. Usually a 4 stroke can be very rich and not foul plugs, provided there isnt oil in the burn.
Which conditions do the plugs foul at? Idleing, 1/2 throttle, or wide open? Once you figure the conditions that cause the plug to foul, then I can help you figure out what to do.
Old Jul 30, 2004 | 02:33 PM
well the thing is i have tried to single it out but when i run full throttle and then stop it wont start again becuase the plug is fouled. if i ride it normally and then stop it wont start up again becuase the plug is fouled. but when it is idleing it doesnt seem to foul plugs as often.. so i guess it is fouling between half and full throttle. does that help any i really would like to fix this i have been wortking on it for about a month and a half.
Old Jul 31, 2004 | 11:20 AM
Are you buring any oil? Have you done a compression test yet?
Is the motor stock.....exhaust and air filter and air box?
Either its grossly rich, or youre buring oil.
Try running with the air box lid off, this will lean it out, and see if that helps. If it doesnt help then youre probably burning oil.
If its burning oil, you got two choices...rebuild the motor, or run a hotter plug.
Cole Hadden
Jun 15, 2025 09:05 AM
MIKEYTRXSHEEBANGS
Dunes and Dune Machines
Aug 27, 2015 12:57 AM
Espo720
Technical and How-To Articles
Aug 19, 2015 02:44 PM
DanP24
1) Engine problems..
Aug 12, 2015 11:39 AM
